stepep
- Joined
- Sep 28, 2009
- Messages
- 59
Thanks mate!You will need to take the reflector out first, you will need a grippy material to loosen it, such as utility gloves or anti slip material once the reflector is out you can get to the led, people have fitted several types such as xre or XPG or XML which I have done, if you are unsure best to leave it to an experienced modder but it is fun to do but be careful! There are several threads on hds modification
