P60 Host - Ahorton Aspherics and Kit compatability
ahorton
The aim of this thread is to be a searchable resource which can tell you which P60 hosts work well with my 27mm aspherics.
I should have started this a year ago. I see the same question often in different parts of the forum "Will it fit in my XXXX YYYY?" and I usually can't answer it because I don't own every host.
To make a start, I have copied the excellent host list by orbital. As I gather information I'll update this post. So if you can help me out, then please post below with any information you can offer.
The sort of useful things we'd like to know are:
Make + Model
Does the lens fit?
Does the kit fit?
Is the ring in the kit used?
How does it fit; Is the lens under a bezel, inside the head with a retaining ring, inside the head with just the spacer etc?
Is waterproofing retained?
Does the lens protrude or is it protected?
+ anything else you think might be useful.
The more info you can offer, the better, but anything is better than nothing.
I'll also try to add references, either as a member who has tried it, a picture or a thread etc.
Aurora SH290, X-06-1/2/3
Blackhawk Falcata
Brinkman Legend, Maxfire (LX models on both)
Brinyte TA-01, TA-02A/B
Cabela's XPG (Xenon models)
Dereelight CL1H (V1~4 & T), Javelin
DealExtreme {DX} HF-19, SKU: 1284, 4226, 14226, 14329, 14597, 14902, 15159 (DIY), 15565, 15561, 24354
Elzetta ZFL-M60 {designed for Malkoff M series drop-ins}
FARKA F8 (may need slight modifications per drop-in)
FireKylin Bailiff & Tactical (T95) Series
Fireworm F1 {Titanium}
FiveMega AA & all 18mm bodies
G&P M3, T6, T9, T12, R12
G&R SST-50
Hellfighter
X-4, X-8
Huntlight FT-01PJ, FT-01X SE (Luxeon versions on both)
Kaidomain KD Tough, T3 from TLS
Leupold MX series w/ MX-100 bezel
LumaForce
LF1
LumensFactory Seraph SP-6, SP-6Ti & SP-9
Malkoff
MD2 & 4, Twisty {designed for Malkoff M series drop-ins}
M812
Mega CREE Q2
MTE M6-2
MX Power Cree 2xCR123A, ML-600, ML-660
Nextorch GT6A-S {Nylon 18650 host}
Pila GL2/3/4
Romisen RC-E4, RC-M4, RX-A
SKYRAY S-R5
SmallSun ZY-C73
Smartfire A-1, T1, see Ultrafire models
Solarforce L2 (several Special Edition L2), L2i, L2m, L2P, L2r, L2T*, Stainless L2T, L2X, SF6, SF9, SF12
L2, L2P - Fit well, Ref: comments by psychbeat (post 90) and others
Spiderfire Q5, R2, X-O3, X-666
Superfire C1, see Ultrafire models
Surefire
{SF}
3P, 3R
6, 6P, 6PD, 6PL, 6R, 6Z
7Z
9P, 9Z
C2, C3
D2, D3
G2, G2L,
G2Z, G3, G3L, GZ2
M2
Z2, Z2-S, Z3
Z32 - shock isolating head. Fits really well without the ring. Waterproofing is maintained.
Ref: Comment by ^^nova^^ (post 87)
>> Surefire Weaponlight models
> 617FA, 617FGA
, 617FLG, 617LF
> 618FA, 618FGA, 618LF, 618LFG & 620LT
> 621FA, 621FGA, 621LF
> 623FA, 623FGA, 623LF, 623LFG
> 628, 628F, 628L, 628LF
> 636FA, 636FGA, 636LF, 636LFG & 660
> M951XM07, M952XM07
> P111
Tank007 Pt10
Trustfire
T1-Q5, TR-B1/2/3, TR-C1 & 2, TR-C6, TR-Q5, TR-Q8
TR-C2
Ultrafire 6P, 9P, 12P, C1, C309, Alpha-C1, L2, M5, SG.DX-B, UF-762 Firearm Mount
WF-501A~D, WF-502B~D, WF-503B/C + extension option, 504B
WF-502B - Fits with entire kit inside head. Lens is sunk and protected. Waterproofing is lost unless silicone is used. Ref: ahorton
UniqueFire L2, M2, R5
Vital Gear F2
Wolf-Eyes See Notes:
XLight HA-III Cree Q3 kit, HA-III Cree Q5, HA-III 14500
XTAR P4
Zhongwin Farka F8, Xeno G5 {only original versions for both, compatible as P60}.. manufacturing dates needed~
ahorton
Reserved for pictures.
If you have a picture which you don't mind me using, please post it below or send me the link (to your image sharing site) and I'll copy it here. Pictures of the head and lens which show how it fits are best.
