Hellbore
10mm LED\'s from Radio Shack?
I bought 4 10mm leds from Rat Shack and hooked them in series to the 12v line of my computer power supply. I believe the LED's said that they work at 4 volts. However, they only lasted a few minutes before one burned out.
I thought that hooking LED's in series meant you could divide the source voltage by the number of LED's to get the right vf for the leds. If the leds were 4 volts each and the source was 12 volts, shouldn't 4 in series have worked?
Any advice on this would be appreciated. In contrast, I hooked six 5mm LED's in parallel to the 3.5 volt line of my power supply for some accent lighting on my case and they work great. These LED's were bought from superbrightleds.com so maybe they were better quality?
