lilmarvin4064
- Joined
- Oct 13, 2004
- Messages
- 47
I'm working on lamp project that involves (at least) 3 different LED colors; white, amber, red, + ? and have many questions. I've rethought this idea over again completely a few times and I'm starting to get a little frustrated and need some help.
This will be an uplight, no optics. I initially intended to use XMLs for the white, Rebel PC ambers and XPE reds, + maybe 1 Rebel deep red. I'm trying to create a lamp that can be adjusted from 5000K "daylight" or "full spectrum" if you could call it that, down to 1700K - 1800K candlelight. what would you use?
I'm now considering other options for the white, as the XMLs have color separation at the edges (warmer) and are less uniform. So I'm now looking for something in the Bridgelux format without the dome. 5000K - 5500K with a decent CRI, 80 or better, or in combination with other colors to fill out the sprectrum. Simplicity would be nice, but if color mixing (cyan, violet, red, etc) wouldn't be too difficult to mix and increase that CRI, then I would consider this option.
The Vf of each color (5000K, Amberish, Redish) needs to be <24V.
What combination of Amber (Rebel PC Amber or other) lumens + Red (630nm + 660nm?) lumens do I need, to make 1700K? (add white?) I was considering the red mix as 2/3 630nm + 1/3 660nm. ? advice?
Some research led me to believe that If I mix 2/3 lumens from white + 1/3 lumens from amber, I can make 3500K.
I have about 20 - 25W worth of heatsink area to work with.
I was thinking something along the lines of 900 - 1200 lumens of (5000K-ish), 400-700 lumens of amber, and 300-400 lumens of red. Does this sound about right? keep in mind, each color will be adjustable and probably won't all be at full power simultaneously.
any thoughts on LED selection or otherwise?
Thanks
Thanks
