Wuben
Results 1 to 9 of 9
Thread: What makes one flashlight brighter than the next....
    May 2011
    IN
    Default What makes one flashlight brighter than the next....
    I got to thinking about this and would like your opinion. I know the led how hard its driven, reflector type and coating, optics, type and coating of lens and so on. Also the beam style makes a big difference to my eyes along with tint.
    Anyone care to take a stab at percentages? like....
    25% driven
    35% led
    10% lens/coating
    3% reflector/coating
    7% tint
    5% bin label
    15% beam/illusion
    Curious to see what others think.
    Oct 2009
    Seattle,WA
    Default Re: What makes one flashlight brighter than the next....
    It's primarily the specific LED and then how hard it can be driven. Most of the other factors are just dealing with inefficiencies.
    If there is no reflector or if it's diffused you have flood and the greater the diameter of the reflector the more throw you will get for that particular LED.
    If something is not driven as hard as its specs allow then driving it harder will result in more output.
    Flashaholic* B0wz3r's Avatar
    Sep 2009
    San Francisco Bay Area
    Reflector characteristics are also important too. A dedicated thrower that produces more actual light can look dimmer than one that produces less light but spreads it out more evenly. When you concentrate the light in a small area, you get high lux values, but lower lumen values, but of course you get much more range as a result.
    What? Me? Derail a thread?
    Aug 2004
    Sacramento
    Nana Re: What makes one flashlight brighter than the next....
    More lumens!!!
    Welcome to CPF
    Apr 2009
    Ontario, Canada
    Ohm's law.
    Flashaholic* The_Driver's Avatar
    Jan 2010
    Germany
    your forgetting something very important: -size of heatsink - how good the thermal path between the led and the heatsink is - what material the heatsink is made of etc.
    Other than the light output of the emitter.
    Reflector/Optics in my opinion can detract the most.
    May 2011
    IN
    Thanks all for the replys. I have noticed there are alot of lights with the same leds(some different bins) and guessing driven close to the same given the runtimes and there are good size differences in brightnesses to my eyes. Was curious at what made the differences. Again thanks for all the replies.
    Oct 2009
    Seattle,WA
    Quote Originally Posted by 340wedge View Post
    In that situation it's the size of the reflector which is changing your perception as BOwz3r mentions above.
