Having multimode on twisty is pain in a_ _ as its quite easy to switch mode accidentally while pressing
and twisting to change mode is quite inconvenient
I prefer single mode on twisty
$.02
I'm also looking for a 6P drop-in LED module. Do you know the runtime for the above drop-in?There are hundreds of options, but as a 1st led drop-in purchase, I recommend this one:
http://www.batteryjunction.com/thrunite-p60-xml-3m-9v-neutral.html
It is nicely priced, plenty bright (460 lumens) gives you 3 levels of brightness... But best of all is the 3500k color temp... A little more neutral white than the incan youre used to, but none of the sickly, ghostly blue of the typical budget led module... And I can vouch for the quality, I have 2 of them and Thrunite builds solid products... Lastly the module is an XML led even though the photo shows what looks like an XPG... Go for it!
why stick with the CR123s?
as to insert: forget malkoff and check with member nailbender's makes.
These are the ones any other are to be compared (and none can stand ground, not even those picey ones)
just got my m61 drop in, all i have to say is HOLY %$&!!!
