PC10 was DOA!
Casebrius
Cajun Heartland
I just received a Jetbeam PC10 and it won't work with RCR123's. The high mode came on briefly and then wouldn't come back on. The low mode will work but that's it. When I try to cycle in user mode, the medium and strobe flash briefly but won't come on. Has anyone else had this problem?
JohnnyBravo
USA, Idaho, Boise
I have it's brother, the PA10. Just the turbo mode works with a 14500, but all modes work with an AA. Have you tried your light with a primary CR123 yet?
Chicken Drumstick
UK
The PC10 should work on all modes with RCR's. At least that's what JetBEAM said when I asked them.
Stephen Wallace
London, UK
I can confirm that all modes should work with 16340 cells as well as with CR123A cells. Turbo and high become pretty similar when using 16340 cells (basically identical if you use an IMR), but the medium and low settings should still function and be very different to each other and to the high/tubo settings.
