Hey all, I'm planning to build a super thrower LED Maglite, and would like to run a couple things by you. I've combed through tons of threads on this subject, and I think I've come to a basic understanding, but I still have a couple of questions I can't resolve. So far, I've found that:
1. The Cree XR-E would be the best option for an emitter because puts out most of the light straight ahead, and doesn't have an odd pattern. Higher bins mean higher brightness; an R2 should be a good option.
2. An AMC7135 based driver is cheap and reliable. It somehow senses how much voltage the LED needs, and burns off the rest as heat. The current is regulated, in this case it should be to 1050mAh. The driver won't boost the voltage to keep the brightness consistent as the batteries drain, but it won't flicker either.
3. A 3D light would be ideal because the 4.5 volts from the battery will be closest to the 3.7+whatever the driver leeches volts that are required, so not too much power is wasted.
4. This DX SKU 12834 aspherical lens will just drop in if I grind most of the reflector off and use it as a retaining ring.
5. The H22A heatsink will keep the emitter and driver from being damaged, and keep the emitter low enough in the body so that the lens can focus it.
Assuming all that's correct, I'm still not sure where to solder the leads onto the driver and emitter (can't find any pictures for some reason). Also, where do you guys get your emitters and drivers? I can't find that exact emitter on DX, and although they do have the driver, they only seem to come in 10-packs.
Thanks!
DX Link Removed, replaced by SKU - Norm
Thanks!
