I am not concerned with the size for my project, the 28mm diamater will suit me fine. I am more wondering what kind of beam it will produce? Is it more spot or flood pattern? Or is it a nice mix? I am Doing a project that will use either 36 xml emitters or 8, ssr-90 emitters. I am just trying to imagine how it would look with 36 xml emitters with that reflector on each one. Or if I should use that reflector for half and the other half use a different reflector for more spot or flood beam depending on how the beam is using the XML-10R.
You are right up the road from me in the DFW btw. Would love to check out your projects sometime.
