Onthelightside
I was just wondering if replacing the 2 CR123 cells with one 17670 will be ok voltage wise for my Quark 1232 "X" . I know some will be destroyed when you overdrive them so I wanted to make sure before I did it. Thanks
Some quarks run in the .9-3.9 range. These ones are incompatible with li-ion rechargeable batteries and are intended to run 2xAA, or 1 CR123's.
Might effect their longevity no?
Ok thanks for your replies. I was pretty sure it would work but I thought I would check and not ruin the new light I plan on using AW cells and the 4sevens charger. Sorry I posted in the wrong section
