roadkill1109
- Joined
- Mar 11, 2011
- Messages
- 2,309
Note the thick wall of the tubing, and just like the version before it, it uses extension tubing for 2x18650 format:
Note the front as it now sports an SS Bezel:
Here's the extension tube attached to the light, it fits between the head and the original tube.
Here are more photos of the light:
Spec Sheet:
LED: CREE XML U2 Lifetime 50 000 Hours
Max Output: 850 Lumens @ 3A for 110 Minutes
Reflector: Smooth
Circuit: Step up and down constant current driver,with high efficiency dual mode DC-DC regulator (PWM / PFM)
Lens: Toughened ultra clear glass with AR coating
Body: Hard Anodized Type III Aerospace Grade Aluminum Alloy T6061-T6
Colour: Black
Run Time by Battery Type
- 4x CR123A 800 Lumen 85 Minutes
- 1x 18650 Li-ion 650 Lumen 60 Minutes
- 2x 18650 Li-ion Battery 850 Lumen 110 Minutes
Working Voltage: 2.75V to 12V
Waterproof: IPX-8, beyond 5m depth
Size: Head diameter 62mm, Length 251mm
Reflector: 58 mm diameter x 55 mm deep
Candle: 25W daylight over a 30 sq.m area
Remove the reflector housing,
Weight: 287 grams, excluding battery
Extras: Spare O-Rings
I was told that this light throws better and is much brighter than the first version.
Is this going to be the ultimate thrower in its price/size/format range?
Spec Sheet:
Reflector: Smooth
Colour: Black
