roadkill1109
- Joined
- Mar 11, 2011
- Messages
- 2,309
LD12:
• Cree XP-G (R5) LED with a lifespan of 50,000 hours
• Uses one 1.5V AA (Ni-MH, Alkaline ) battery
• 105mm (Length) x 21.5mm (Diameter)
• 54-gram weight (excluding battery and holster)
• Digitally regulated output - maintains constant brightness
• Reverse polarity protection, to protect from improper battery installation
• Anti-roll, slip-resistant body design
• Tactical tail cap switch with momentary-on function
• Side mode switch in the front
• Premium Type III hard-anodized anti-abrasive finish
• Toughened ultra-clear glass lens with anti-reflective coating
Notice: The above-mentioned parameters (tested by 2500mAh Ni-MH battery in Lab) are approximate and may vary between flashlights, batteries and environments.
IMPT NOTE: Fenix confirmed this LD12 will run a 14500 cell!
LD22:
• Uses two 1.5V AA (Ni-MH, Alkaline ) batteries
•156mm (Length) x 21.5mm (Diameter)
• 60-gram weight (excluding batteries and body clip)
• Digitally regulated output maintains constant brightness
• Reverse polarity protection guards against improper battery installation
• Push-button tail cap switch with momentary-on function
• Side mode switch in the front, fast and convenient
