Any mag with 30W of power in a standard mag body wont be practical
On high my 3x P7 light gets excessively hot somewhere in the 5-15 minute time frame depending on ambient temp and how much airflow is over the head. So hopefully he wont be battery limited off of a fresh charge.
Also, with a 4/6 mode der-witchtel driver he can turn it down. My 3xP7 light is used at the 25% or 3% setting most the time. Which could turn it from completely impractical to useable. The DW driver would be easier then trying to fit 3x multimode amc driver boards under the heatsink, or stacking 2 AMC chips on top of the existing ones on a 2800mA board. The triple stack of chips would be a workable solution though, if done nicely and the chips were secured with epoxy for additional stability, provided drivers will fit into the heatsink's opening.
