Chicken Drumstick
of my new Klarus NT20.
Got it through last week after having to wait for a couple of weeks for delivery from China.
Have to say I'm very impressed so far with it, very solid feeling and lovely build quality. The beam is certainly more floody than anything though, which makes it great in more confined areas and closer out door environments. The hotspot is very smooth and blends lovely into the spill, so it produces a wall of light rather than a concentrated hotter centre area. This does seem to limit throw though, even when compared to my EagleTac D25LC2.
Currently I'm running it on some CR123a primaries, which seem to be holding up pretty well, some RCR123's are on the cards though. Thus far I like everything about this light, it tail stands with ease, is nice in the hand, feels solid and easy to use. The included holster is very nice too and compact unlike the one for my EagleTac D Series which is flippin huge (even though the EagleTac light is smaller than the Klarus :duh2: ).
The only two negatives I've got, are the clip, which in itself is fine, but when compared to the EagleTac D25LC2 is nowhere near as good. Not as solid feeling, doesn't clip on/off of your jeans pocket as easily and isn't as long. It's also mounted mid way along the light and not at one end. In fairness though the NT20 is longer overall, so it might not fit in a pocket as well if the clip where mounted on the tailcap.
The only other minus point is the tail cap is indented, and it would have been nice if when full tightened it aligned perfectly with the grips and side switch, but it's about 1/4 of a turn out. But these are minor gripes on an otherwise superb flashlight.
The BEST bit is however the UI. It's got 4 levels of brightness, strobe, signal and all the other gimmicks. But what I like is how easy it is to use the modes you want and totally ignore the others.
The tail switch is the on/off and also does momentary. When powered on, the side switch then selects low - med - high. But what I like is it'll remember what you left it on. I find I use med most of the time, so switch it off and on and it's just how you left it! Fantastic. :thumbsup:
But what's even better is, if you twist the head it then goes into an ultra low mode, you can do this with it on or off and it'll still remember your Low - med - high choice when you re-tighten the head.
I like this as it allows me to switch the flashlight on in ultra low or my last setting. There's no cycling through different modes at all. And if you don't want the beacon or SOS modes, you'll never see them at all. And I do like that strobe is activated by holding down the side switch. So again you never see it, unless you want it. And it takes but a second to access it (one handed) should you ever actually need it, rather than faffing about with a dozen different clicks to get to it.
No beam shots yet (I'll try and get some soon). But I've got some comparison shots with my EagleTac D25LC2 and an Eneloop powered CREE SK68.
Comparison on high/turbo (max output)
-EagleTac D25LC2 = 343 lumens
-Klarus NT20 = 280 lumens
-CREE sk68 = ??? lumens
Same shot but different exposure
Lowest output modes
-EagleTac D25LC2 = 3 lumens
-Klarus NT20 = 2 lumens
Lowest output modes
