So I finished my ROP Mod, yes yes I know, that mod is way to old to be interesting, but hear me out. The setup is as follows:
12 2500 mAh NiMh made in Japan (Duracell).
that is two 6x packs in parallel.
With this setup I have less current draw per cell, half the demand, and should thus be pushing a stable 7.2 Volts without too much sag due to asking too much of the cells.
Anyways, there are two problems, the beam is too floody . But worse of all, the damn thing does not look like 1000 lumens.
I am comparing this to a 4sevens quark 123^2 XM-L that should produce about 360 Lumens (I got the neutral version), and it doesn't seem all that much brighter. It does produce a lot of heat though, if I hold my hand in front of the lens it gets warm quite quickly.
Could there be anything causing the light to be dimm? Do I perceive it to be dimmer because it is so floody? or did I simply expect too much from the ROP?
thanks
thanks
