mporter
I'm a newbie here, so please forgive me if this tip has been posted before.
To make a tail stand for my new LSH-P, I found that semi-flexible PVC tubing with an ID of 3/4-inch is a perfect press fit over the rubber switch. I cut about a 1/2-inch length, just longer than the rubber switch. In place, it adds almost nothing to the dimensions of the light, so it's easy to carry with me. That it's soft and flexible also helps.
Now, when I want, I can stand my LS up and get a diffuse light bouncing off the ceiling.
A more elegant looking but slightly bulkier stand is the standard 3/4 inch PVC pipe plug. It has a flat octagonal base and an inside diameter and length just right to press fit the LS switch. Works perfectly off the shelf. No modification necessary.
