I've started noticing something strange with my 4Sevens Quark "X" 123-2 flashlight.
The difference between high and turbo used to be very robust. But now, when the light is first turned on, there is a negligible difference between high and turbo. After switching back and forth a few times, there's no longer any discernible change at all.
Some of you may know that the output of the Quark "X" series drops after three minutes on turbo. This is not the source of the problem, as the whole test takes only, perhaps, 30 seconds.
I have also considered that the flashlight was not properly switching between the tightened and loosened bezel modes. However, I am able to cycle through the tightened and loosened bezel sequences normally, so that can't be it either.
So, as far as I can tell, it's either got to do with the batteries getting low (I'm still on my first pair of batteries, so I don't know exactly how the light behaves with low batteries) or it's a malfunction.
Is this a fairly normal occurrence with flashlights, or should I be contacting customer service?
P.S. Rock on, CPFers! :rock:
