Hi guys!
Have 3 "228 lumens LED" bought from DX (yea maybe not the best ones but they work and ill guess they are not really that bad after all) and pulled of the lens to one, which suprised me was made of glass and not plastic, to get as wide beam as possible from them. The second suprise was when i noticed there was this soft silicon thing inside it as i thought maybe was used as a kind of heatsink or so to further transport away the heat because i couldnt really se any other use for it.
I fired the LED up at only 750mA and held a finger some mm from the chip to feel if the chip maybe got hotter or so without it and pretty much burned my finger of after a couple of seconds.
1. The heat i felt is that actually from the chip it self getting this insanely hot even with the heatsink underneath it?
2. Would the chip be totally ok for long-term use even at 1A without the silicone or will it overheat in the length or so?
3. The chip doesnt really have to be protected since it will be in an enclosed reflector but would it be possible to protect it by adding an minute amount of say clear epoxy over it or will there be a risk that it would react with the phosphor so it would be destroyed of maybe even dissolve in it? Water clear silicone is nowhere to be found.
Thanks!
Thanks!
