Dave Wright
In the absence of a legitimate runtime comparison between the Arc AA and the CMG Infinity Ultra, I decided to make one up. I took Roy's runtime curves for the 2 lights and adjusted the scales to match my field measurements of total output and hotspot brightness.
First, the total output plots:
The Arc is brighter through almost all of the burn time. Around the 11th hour the CMG's better regulation allows it to match the Arc momentarily. The Arc has a superior corona; this is probably due to the reflector.
Now for hotspot brightness:
The Arc starts off brighter. Around hour 4 the CMG's regulation puts it into the lead. After hour 11 the Arc takes back the lead as the CMG falls out of regulation.
These differences are probably more academic than of issue in real use. Even side-by-side the two lights have very similar output and usefulness.
I publish these charts mostly to make up for conclusions I posted earlier based on various bits of information gathered from CPF. At the time it looked like the Arc's circuit was as much as 60% more efficient than CMG's. My more recent observations indicate that the difference attributable to the circuit is more like 5% - 15% with a little additional total output difference due to the Arc's reflector.
Not as much difference as reported by some, but more consistent with typical circuit design differences. I'm still on honeymoon with the Arc AA. What a great light!
