kjelrod
- Joined
- Sep 9, 2011
- Messages
- 48
Hello all,
Although this forum has in turn cost me a lot of funds it has turned me on to a hobby that is truely addicting. lovecpf That being said here is my next build.
This was a follow up project
This is a dual lens system. Never throw away lenses you think are useless. Although they may not work individually, as in this case, when combine with a larger lens it makes a great project.
I will post pictures of the flashlight itselt later on once I have cleaned it up a bit. It is still in the prototype/testing phase.
Here is a quick wallshot post compared to the 250k lux previous project I had. I was getting 30,700 at 5 meters but I always scale the number down just in case my meter overreads. The only point of reference I had was an HS802 at 1.6 AMP was doing 30k-31k lux at 1 meter, which seems consistant.
I have put an overdriven xre-r2 ez 900 behind it and am having trouble getting good distances to take measurements at. The beam is smaller than my sensor on my lux meter anywhere in my house. I will get it outside one day.
The design of this setup lets me swap out different maglites very easily since I used a spare head I had as the base of the system. Here are a couple of pictures to give a taste. I will show more pictures as I complete this light including outside beamshots.
Now because I used a collimating lens the image of the die is actually larger. I didnt gain any measured lux, i think I even lost a tad(15k-25k), however there is much more light in the beam now and a perfect led picture.
Enjoy and thanks for looking!
250k lux XML
250k lux closer
750k lux xml
750k lux closer
BOTH SIDE BY SIDE
Update: Just finished setting up my XREr2 direct drive and got 10,100 at 10 meters. My last EZ900 so I have been super careful with it.........
250k lux XML
250k lux closer
750k lux xml
750k lux closer
BOTH SIDE BY SIDE
