SOLD/Moved/Withdrawn Assembled P60/D26 Drop XPG, XRE, XPE, XML MORE ADDED
I have some more assembled drop is for sale. All are thermal injected except for number 1, 2 and 3 where space is not possible due to the large driver. I tested and write each current draw and voltage range on the reflector itself. Thanks for looking!
SOLD 1. XML-U2, High-Medium-Low With memory, Extremely low .8-4.2V working voltage, Work on 1, 2 or 3 alkaline, 1 CR123A or any 3.7V Li-ion, 2.4A on high with 18650, smooth reflector, Beautiful pure white beam that throws! $40
SOLD 2. XML-U2, High-Medium-Low With memory, Extremely low .8-4.2V working voltage, Work on 1, 2 or 3 alkaline, 1 CR123A or any 3.7V Li-ion, 2.4A on high with 18650, smooth reflector, Beautiful pure white beam that throws! $40
SOLD 3. XML-U2, High-Medium-Low With memory, Extremely low .8-4.2V working voltage, Work on 1, 2 or 3 alkaline, 1 CR123A or any 3.7V Li-ion, 2.4A on high with 18650, smooth reflector, Beautiful pure white beam that throws! $40
4. XPE-R2, Single mode, 3-6V working voltage, 1.5A, Smooth reflector. Very tight defined hotspot. Excellent throw with a slight donut hole. $28 $23 $21
SOLD 5. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Light OP reflector. Very bright with a beautiful defined hot spot that throws. $30 $25 $23
6. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Smooth reflector. Bright define hot spot with a slight donut hole. $25 $20
7. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Light OP reflector. Bright with a very cool white tint and a tiny hint of purple. $20 $15
8. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Smooth reflector. Very bright with a beautiful defined hot spot that throws. $30 $25 $23
SOLD 9. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Smooth reflector. Very bright with a beautiful defined hot spot that throws. $32
SOLD 10. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Smooth reflector. Very bright with a beautiful defined hot spot that throws. $32 $27 $25
SOLD 11. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Smooth reflector. Nice beam with that towards the neutral side. $30 $27 $15
12. XPG-R5, Single mode, 3-6V working voltage, 2.1A, Smooth reflector. Really throws but has a donut hole. $20 $27 $25
13. XPE-R2, Single mode, 4.5 working voltage, 1.4 A, Smooth reflector. Very tight defined hotspot. Tint towards neutral side. $25 $20 $18
14. XPE-R2, Single mode, 4.2 working voltage, 1.6A, Light OP reflector. Nice define hot spot. $25 $20 $18
SOLD 15. XRE-R2, Single mode, 3-6V working voltage, 2.1A Light OP reflector. Beautiful Thrower Beam. $32 $27 $25
16. XML-T6, High-Medium-Moonlight ****With memory, 4.5V working voltage, OP reflector that produce a beautiful but very wide extremely floody beam, Almost no hot spot. 3A. $30 $27
SOLD 17. XML-U2, High-Low always turns on at High. High is direct drive! Extremely bright! Current varies with battery but draws about 4.2A with single an 18650. Smooth reflectors that rally throws! $44
SOLD 18. XML-U2, High-Low always turns on at High. High is direct drive! Extremely bright! Current varies with battery but draws about 4.2A with single an 18650. Smooth reflectors that rally throws! $44
SOLD 19. Seoul HCRI, 1.1A, 4.5V, Moonlight-Medium-High with memory. Smooth reflector. High is probably 100 lumen. $15
SOLD 20. Deerelight XRE-R2 EZ900 pill. Modded to draw 2.1A single mode. Thermal injection on the inside. Epoxy filled on top of the LED for durability. This pill is made strictly for use with aspherical set up such as a Deerelight DBS. $45
SOLD 21. EZ-900 XRE R-2 De-Dome. Dedome perfectly without any damage. 2.1A Single mode. Tested with a 4cm aspheric lens and the focus and intensity is INCREDIBLE! $45 $40
SOLD 22. XML 4500K. The tint is BEAUTIFUL! 4A High-Medium-Moonlight with memory. Beautiful beam shape. OP $44
23. XML 4500K. The tint is BEAUTIFUL! 4A Moonlight-Medium-High with memory. Beautiful beam shape. OP $44
24. XML 4500K. The tint is BEAUTIFUL! 4A High-Medium-Moonlight with no memory. Beautiful beam shape. OP $44
Paypal:
[email protected]
