I have long suspected that the new Luxeon III LED's are really 1W devices that have been repackaged with some slight process tweaks to handle larger drive currents. In order to support my stance, let's take a look at some numbers, shall we?
Current high flux 1W such as the R bins are rated at 39.8 Lumens minimum and 51.7 Lumens maximum. From the curves that lumileds provides on their 3W parts, you should realize a 60% increase in luminous flux output when going from 350mA to 700mA. Now let us take this 60% number and apply it to the R flux outputs.
39.8*1.6 = 64 lumens at 700mA minimum
51.7*1.6 = 86 lumens at 700mA maximum
Compare these to the 3W specs:
60 lumens at 700mA minimum
65 lumens at 700mA typical
Judging from these numbers, it's hard to discern a 3W part driven at 700mA from an R flux 1W driven to the same level. Remeber that a few lumens difference cannot be detected by the eye, unless of course you're the Bionic Man. Only a calibrated integrating sphere will be able to discern the difference. We're talking a piece of equipment that's out of reach of the typical flashaholic.
My conclusion is that the 3W device is an extremely close twin of the high flux 1W device. Lumiled's has improved their processes sufficiently to get a viable yield on the high flux parts to offer them as "New" parts. I'm not saying it's a marketing gimmick. I am saying that through the evolution in process technology, higher flux (and better thermal management) single die LED's were inevitable. You cannot sell these "new" parts at a premium without differentiating them from the vanilla 1W devices. Better thermal management, I believe, is the primary differentiator and that high flux dies were bound to become more common as the process to make them improved. I also suspect that dies that fail flux output tests will probably find their way into the more mainstream 1W parts, sold as lower flux parts. So those newer P's and Q's coming out of their fabs are most likely a a fallout from the screening process to make the 3W parts. I offer this conclusion as merely my own opinion and not necessarily gospel or truth, as I am not an authority on this subject by any means. Any differing view point is solicited here. No flames, please /ubbthreads/images/graemlins/grin.gif
CM
CM
