recycler
- Joined
- Apr 28, 2011
- Messages
- 40
hi guys
my other usb project remains unfinished, i have been asked to build a torch for a friend, my line of work is nightshift as much as it is dayshift, over the years ive been seen with various headtorches which have all been home made and been "wow"ed over by collegues.
So, on a request ive made another, its current state its missing a wire so completed photos are not available yet and will post soon.
I was supplied with a battery a 2s2p NMH pack at 8.4v, so the build started from there.
I decided to use an XML T6 with a Laura reflector along with a 5 mode DX driver, unfortunately no matter how much squeezing i just couldnt get the 5 mode driver to fit, as a daughter board i decided to remove it, and fit the single mode until i can find a similar spec board with a smaller stack height
Enough talking, everybody likes pics
And here we have an almost complete torch, the horseshoe you see is what holds all together, it took a long while figuring out how to do this.
There was no drawings or sketches, each part is unique and machined on the fly out of my head
as to what seemed best at the time,
The rear and front of the light head are a tight interferance fit, they can be pryed open via a smallgroove between the units, they are also stepped to aid contact surface internally
I do not have any screwcutting gears as of yet, so unable to cut threads, my faithfull and worn lathe is about 80 years old and still cuts lovely
here are all the parts
and finally the pre-assembly box
so, opinions gratefull.... more to come when i get hold of a suitable cable
