Imalent
Results 1 to 3 of 3
Thread: Fenix TK11 and Li-Ion batteries
    Default Fenix TK11 and Li-Ion batteries
    Hi all. I have a Fenix TK11 that is over 3 years old. I run it on (2) CR123 batteries. Are these older versions compatible with 18650 Li-ion batteries? Thanks in advance!
    Regards,
    Frank A.
    Flashaholic* SimulatedZero's Avatar
    Nov 2011
    SouthEast, USA
    Default Re: Fenix TK11 and Li-Ion batteries
    It should be able to fit a 18650. I know that several of the older models do, but I don't know which one you have. Put in a couple of CR123's and look at the battery tube with the tail cap off. If there is some extra space around your CR123's then it's a good bet that it can fit an 18650. If it's a tight fit around the CR123's then it's a no go. I don't remember if all the older versions could fit an 18650, but I believe so. I know that the old TK12's wouldn't fit one but the old TK11's would. Hope this helps.
    "Maybe you should just stick to fire on a stick... it's received excellent reviews here - plus it's a time tested design..."
    The 18650 fits, I just want to make sure I won't fry the pill. Thanks.
