Two different lights.
1. Surefire C2 mod with a P60 drop-in. I turned a piece of copper and AA'd it into the recess of the brass heatsink to add mass. 2.8 amp driver (Shiningbeam)
2. Maglite mod with H-22A heatsink that I cut the tower down flat to accommodate the 20mm star. Star glued on with Arctic Silver ($$$). Direct drive off 3 alkaline D's. 3.36 amps at tailcap.
No blue light seen on either light. I'm wondering if the melting point of the solder some guys are using is too low? With good heatsinking the XM-L should be good for 3 amps. Am I correct?
Thanks,
Greg
Thanks,
Greg
