Acebeam
Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 121 to 150 of 351
Thread: Boring service for Surefire and other aluminum or titanium lights
  1. #121
    Flashaholic* BenChiew's Avatar
    Nov 2011
    Malaysia/Ship to Portland, Oregon
    Default Boring service for Surefire® and other aluminum or titanium lights
    You are the maestro Barry.
  2. #122
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    Default Re: Boring service for Surefire® and other aluminum or titanium lights
    Quote Originally Posted by Benchiew View Post
    agreed. he's got experience.
  3. #123
    Nov 2011
    Tracking number received from Barry.
  4. #124
    Just got my SF P2X back. Excellent work and turnaround time. My AW unprotected 18650's fit perfectly, I just had to put a small rare earth magnet on the cell so it would make contact but that is because the cells I am using are not buttonheads, nothing to do with Barry's work. Thanks Barry!
  5. #125
    Just wondering ........ wouldn't a 16550 battery work just fine without having to bore the fury and 6px bodies ?
  6. #126
    *Flashaholic* precisionworks's Avatar
    Apr 2007
    Benton Illinois
    Quote Originally Posted by abnjeffy View Post
    Just got my SF P2X back. Excellent work and turnaround time. My AW unprotected 18650's fit perfectly, ...
    Thank you for your kind words.
    Those cells run around 2100-2200 mAh versus up to 3400 mAh for the 18650. Runtime is dramatically shorter.
    Surefire® boring including E-Series & Weapon Lights* Please text msg, phone or email through contact page at https://precisionelectrical.us/
  7. #127
    Quote Originally Posted by precisionworks View Post
    is the brightnes the same?
    what is your runtime estimates for a 2200 mah 16550 vs a 3000 mah 18650?
    thanks
  8. #128
    Apr 2007
    Benton Illinois
    Quote Originally Posted by RIX TUX View Post
    In the 6PX lights the brightness is identical with 2xCR123 & with any rechargeable cell.
    ... what is your runtime estimate for a 2200 mah 16550 vs a 3000 mah 18650?
    Comparing total available watt hours per battery gives a good indication ...
    BASELINE 2xCR123 6v x 1400 mAh = 8.40 Wh (this gets a power value of 1.00 to keep it simple)
    16650 3.7v x 2200 mAh = 8.14 Wh (power value of .97)
    18650 3.7v x 3000 mAh = 11.1 Wh (power value of 1.32)
    18650 3.7v x 3400 mAh = 12.6 Wh (power value of 1.50)
    SureFire states runtime for their lights as “tactical runtime,” which is time until output drops to 50 lumens.
    SF shows the Fury with 2xCR123 will reach 50 lumens after 90 minutes.
    The 16650 2200 mAh should reach 50 lumens at 87 minutes.
    The 18650 3000 mAh should reach 50 lumens at 119 minutes.
    My testing with 3400 mAh cells shows 50 lumens at 145 minutes.
  9. #129
    [QUOTE=precisionworks;4276322/]In the 6PX lights the brightness is identical with 2xCR123 & with any rechargeable cell.
    the same for a Fury?
    and thx for the valuable information on the battery runtimes - its great !!!
  10. #130
    Apr 2007
    Benton Illinois
    The Fury output is identical with primaries or rechargeable cells.
  11. #131
    Apr 2007
    Benton Illinois
    It looks like the new SF Fury P3X is close to being available & one should be in my shop within a few weeks. Planning to bore the light + a 1-cell extender & run 2x18650. Some things to consider about this mod:
    From the factory the light is designed to run 3xCR123 & that means the board components are rated for 9 volts. One of the limiting factors on any driver board are the capacitors & they come in the following voltage ratings - 3V, 4V, 6.3V, 10V, 16V, 25V, etc. Best guess is that Surefire will use 10V rated components on the P3X. Since 2x18650 produces 8.2V (cells right off the charger) that setup should be very nice.
    Run 3xCR123 primary cells if you need shortest overall length.
    Run 2X18650 rechargeable cells (requires SF A19 extender or equal).
  12. #132
    Unenlightened Nostrajoshmus's Avatar
    Apr 2013
    San Diego
    I just picked mine up yesterday, theres no voltage rating anywhere on the packaging. My first thought was to go with 2 18500's?, much like the bored c3. The bezel is cemented at the threads so i couldn't remove the head. any advice on how to get that bad boy off?
    Lux et veritas​
  13. #133
    Apr 2007
    Benton Illinois
    Quote Originally Posted by Nostrajoshmus View Post
    I just picked mine up yesterday, there's no voltage rating anywhere on the packaging.
    I don't believe that SF has ever listed a voltage rating on any of their lights. They figure that most owners will run what came with the light, 3xCR123. As long as you stay at or below 9V the driver circuit should be happy.
    The length of 2x18500 is within 1/8" of three primaries & the voltage is slightly lower so that's good but the 18500 gives slightly less runtime than primaries. Using the same math as in post #129:
    BASELINE 3xCR123 9v x 1400 mAh = 12.60 Wh (this gets a power value of 1.00)
    2x18500 7.4v x 1600 mAh = 11.84 Wh (power value of .94)
    2x18650 7.4v x 3400 mAh = 25.16 (power value of 2.00)
    Not really a fair comparison as 2x18650 means adding 1.3" for the 1-cell extender. However, if you can live with the additional length the runtime is twice that of running three primaries.
    Edited comment, method is no longer recommended or endorsed:
    Most heads will come off if the body is gripped in a fixture that allows applying additional torque to the head. So far I've seen only one PX2 Pro & only one P2X Fury with heads that wouldn't budge.
    About half the Fury's (2-cell) have heads that unscrew with only hand pressure but the other half need more force. Sometimes not much force is required, other times it's a lot. I use the setup shown below with a split hard maple block that's lathe bored to the exact body diameter of the Fury & held in a big bench vise. This allows the strap wrench to do its job. I wouldn't expect to see that in any home shop & don't know what else to suggest.
    Early X-Series lights (6PX/G2X/P2X/P3X/etc.) had permanently glued on heads. Most lights during 2013 have heads that unscrew with firm hand pressure. Every recent X-Series light has required boring with the head attached & cost is double that shown above.
    For some time I was unable to a bore light with attached head but tooling is now in place that allows doing just that. Cost is double so let me explain why ...
    A new solid carbide bar had to be factory modified to clear the spring in the head. A new carbide tipped reamer had to be purchased & shop modified to clear the spring.
    Since there's no where for the chips to escape they pack the space ahead of the tool & the depth of bore & depth of ream is limited. The best procedure is:
    Bore 1.00", withdraw tool, clear chips (compressed air and pick), reset tool
    Bore 1.00" more & repeat above
    Bore .750" more & repeat above
    Bore .500" more & repeat above
    Bore .250" more & repeat above
    Bore .100" more & repeat above
    Bore .050" more & repeat above
    Bore .025" more to finish boring to depth
    Repeat all nine steps above with reamer
    Hone dry with ball hones
    Clean & inspect
    Time to run through 9 boring steps + 9 reaming steps + final finishing is more than double the time for normal head off boring. The boring bar & reamer are run as close as I dare to allow full battery seating against the spring:
  14. #134
    Dec 2005
    Georgia Highway 441
    that sounds awesome! this could be the setup to beat
  15. #135
    Apr 2007
    Benton Illinois
    Absolutely
    Surefire really got it together on the 3-cell plus the XM-L2.
    Look at the P2X with primaries vs rechargeable:
    1x18650 3.7v x 3400 mAh = 12.6 Wh
    50% runtime gain with 18650 (which correlates well with burn down testing I've done).
    And the P3X
    2x18650 7.4v x 3400 mAh = 25.2 Wh
    100% runtime gain with 18650 (calculated value, actual results may vary, burn down test will provide real world numbers)
    In the P2X the 18650 is about equal to running three primaries (in total available watt hours). Contrast that to the P3X where 2x18650 is about equal to running six primaries. It is a huge difference.
    Part of this is that the 18650 is the most highly developed battery today - it packs more watt hours into less space than anything else. We can all thank the laptop computer industry - if there were no laptops we'd likely be running 18650 with 2000 mAh or less.
  16. #136
    Flashaholic* neutralwhite's Avatar
    Oct 2012
    Monaco.
    hi there, you know there is a new Elzetta 900 Lumen 3 Cell Flashlight C331 I want to buy , but is it possible to bore it so a rechargeable fits it rather than Primaries ?.
    is it possible?
    what battery could fit 3 cell ?.
    stick to primaries?.
    thanks.
    Malkoff M61T, Jetbeam E21A 5700k 9080 AAA.
  17. #137
    Apr 2007
    Benton Illinois
    Quote Originally Posted by neutralwhite View Post
    ... Elzetta 900 Lumen 3 Cell Flashlight ... is it possible to bore it so a rechargeable fits it rather than Primaries ?
    The 3-cell Elzetta should bore out like the 2-cell & I've already made a dedicated fixture for those lights - which are dimensionally different from Surefire. Not much but enough that nothing in my box full of SF fixtures came even close to working.
    Boring the Elzetta body is done starting at the head & boring toward the tail but stopping just short of the angled tail section. This means you'll always load & unload rechargeable batteries from the head. Cost is the same as any other 3-cell light, $52 for boring + $24 shipping by Priority Mail Intl to Hong Kong.
    You'll need two 18500 cells to replace the normal three primary cells. Runtime on 2x18500 is about 94% of three primary batteries & you will likely notice no difference. Brightness should be the same IF Elzetta designs their driver as Surefire does.
    Cost per hour of operation is where rechargeable cells shine (pun intended). Six cents per hour versus six dollars per hour is a metric ton.
  18. #138
    Apr 2007
    Benton Illinois
    Waiting is the worst part & I'm still waiting - at least LA Police Supply hasn't yet charged my PP account.
    If anyone is planning to run 2x18650 you'll need a 1-cell extender. The Surefire A19 is the gold standard but they are hard to find. AFAIK the only place that has them is:
    http://www.oveready.com/index.php?se...&Submit=%C2%A0
    Dan currently shows 6 in white, 2 in orange & 10 in black HA. All are bored for 18650.
  19. #139
    Hi Barry, it looks like you do amazing work! ...could I ask what you estimate your turnaround time is (roughly) at this point? I have two e1e's and one 6P that need some basic boring = )
    Thanks!
  20. #140
    Apr 2007
    Benton Illinois
    Thank you for your kind words SDmtnbkr & welcome to CPF.
    Lead times right now are 2-4 weeks & that's as quick as they've been in a long time.
  21. #141
    Apr 2007
    Benton Illinois
    Bored the first Fury P3X tonight. The spring at the PCB is small so the recoil shoulder at the front of the tube is bare minimum (0.5mm)
    Total battery projection from the face of the tube to the tip of the cell is 1.0mm
    Look from the switch end of the tube shows the bright ring that's the shoulder:
  22. #142
    Mar 2008
    Borneo
    Cool Barry. This may sound stupid but did you bore it through or did you leave the shoulder there for a purpose?
    With the recoil shoulder in place, will the battery move past it?
    Thanks.
    LJ
  23. #143
    Apr 2007
    Benton Illinois
    Quote Originally Posted by LightJunk View Post
    ... did you bore it through or did you leave the shoulder there for a purpose?
    The shoulder is something that is always left in the earlier model SF's (6P/C2/etc.) All those lights, even with an aftermarket drop in, have a spring that touches the positive contact on the battery. Until just recently the newer PX series lights had no spring so the tube was bored all the way through. SF now includes a spring contact on the PX series so the shoulder can once again be machined while boring.
    A CR123 battery (which is 17mm) will pass through but an 18mm cell will not:
    The very tip of a Panasonic 3400 mAh 18650 is 17mm & that part does come through flush with the end of the tube. The battery quickly widens to 18+ mm & cannot go any father forward.
    It's faster & easier to run the boring bar & the reamer all the way through the tube - stopping both those tools so that they leave a very narrow lip requires much more attention to setup. The benefit is that the driver board cannot be hammered by the battery if the light is dropped head down or during recoil if the light is weapon mounted.
  24. #144
    Mar 2008
    Borneo
    Thanks for the explanation Barry. Nice job on the shoulder
    BTW how much will the damage be to bore and create the shoulder for the P3X?
  25. #145
    Dec 2005
    Georgia Highway 441
    yeah, as LightJunk said that's a great explanation (as Barry tends to do!)
    phenomenal looking (and functional!) work as as usual
  26. #146
    Apr 2007
    Benton Illinois
    Thank you both for your kind words.
    ... how much will the damage be to bore and create the shoulder for the P3X?
    Pricing is the same as other 3-cell lights, $52 + return shipping. For LEO_MIL_FF_EMT it's $44 + return shipping.
    The shoulder shown is machined as far forward as physically possible because of the lead angle cut at the front end of the reamer - the red lines show the angle left inside the front of the battery tube:
    I'll try the next shoulder with a 1.0 mm setback & see if the battery projects enough to make contact with the spring.
  27. #147
    can you do an E2E body to fit an AW 3400 18650? I searched through the thread but didn't see it posted anywhere.
  28. #148
    Apr 2007
    Benton Illinois
    Quote Originally Posted by SDmtnbkr View Post
    Yes I can but no I won't ... here's why. It's physically possible to do but the wall thickness after boring will be 0.1mm or a bit less, about the thickness of a Post-It note. Roll a Post-It note into a circle & the issue is easy to see.
    Boring an E or L for earlier 18650's (up to 3100 mAh) is pushing the limit.
  29. #149
    Oh ok, makes sense. ...so you are able/willing to bore the the 3100 then? Or were you just saying that as a reference? Thanks.
  30. #150
    Apr 2007
    Benton Illinois
    I should have been more clear ... as long as you run AW3100's (or earlier) I'll be happy to bore your light. You'll have to try a few cells to find those that most easily fit the bore since the bore is very close to battery diameter. 3100's seem to be the cell of choice as they run smaller than 2900's & have a bit more capacity.
