How do you get the screen print off the iPhone camera so it includes the buttons and GUI controls?
Very cool... I am confused as to why the whole screen has the lines running through it, as opposed to just the beam, but I tried it for myself and get the same effect. Interestingly very high frequency PWM does not show, like on the Quark Mini AA.
Kinda surprised that a light like that doesn't have any current regulation.
The RRT-0 is also PWM? Guess it doesn't mention anything about current control on their website. Wonder if SWMs rotaries are too (although it says "constant current control"... is that the same as current regulated?). I just assumed all these higher - end lights would be current regulated. :shrug:
Here's a Zebralight H51w on moonlight (one of it's PWM modes) taken on a 5mp new iPad though... Lines are faint and widely spaced, but I can see this light's frequency is quite low (easy to see by waving you hand in front of the beam).
I wouldn't be surprised if any other magnetic control ring lights show this type of PWM.
You can have constant current control and PWM at the same time. They are not mutually exclusive.
Semiman
The current going into the LED during each pulse is regulated and fixed and PWM is simply a cheap way to control the modes. I guess the words you look for are things like linear regulation, regulated buck/book convertor etc. You can easily tell if a light uses PWM though, and it's VERY annoying at night as it feels like you've got a strobe light when you move around.So then, what's the technical wording to look for if you don't want PWM? I think 4Sevens and Zebralight uses "current regulated." And does that mean (in general) if a light doesn't specifically mention "current regulated" then it is using PWM? (like Jetbeam?)
Zebralight specifically states where it uses PWM.... I'm still confused whether or not SWM does.
(edit.... Think I see that the SWM "V" series is using PWM since their "M" series lights do use the wording "fully-regulated constant current.").
You don't need a camera. You need your eyes too look with, and a hand to move the light fast with. Just wave it in front of youre eyes really fast and look at the led.
Happy face with no pwm
Diden't move my hand fast enuff when drawing "smileys", but you can barly see the pwm in some spots on the angry face.
Shutter speed 6 sek. You have 6 sek to "draw your stuff" into the camera Should have used a light with slo pwm frequenzy, easyer to see the pwm with lo Hz. The red lines is me blocking the light with my tumb.
