Labrador72
Hi all,
I wanted to take a picture of the PA10 so I placed it very close to the wall: I noticed that bluish beamspill has outer irregular edges: does not make a clean circle; in fact, in certain points the edges of the side spill are somewhat squared off.
I took a pic of the beamshot (below) using AA (not 14500) - on the embedded picture is not as clearly visible but if you click on the picture and open it in its original size of Flickr is more visible (still less than with the naked eye). I wanted to ask your opinion if this is something to be expected or if it is some sort of defect? I don't have it on any other flashlight but this is the only XM-L I have. Could it mean that the LED is not perfectly centered?
Thanks in advance for any advice you may have.
PA10 close-up beamshot against wall by Labrador77, on Flickr
