Chevy-SS
Just curious what percentage of folks actually like reverse clickies. Personally, I don't understand why anyone would prefer a reverse clickie, but please do NOT let my opinion influence your vote! :devil:
I prefer foward clickies but can see the use for reverse clickies. They are less likely to turn on in your pocket and are more reliable due to less electrode arcing. Of course, both are less reliable than twisty switches. I quote from Selfbuilt, "From the comments I've seen from manufacturers in various threads, the long-term reliability of standard clickies tends to be worse that reverse clickies, for some reason. Hence the prevalence of reverse clickies despite the off-quoted complaints I've seen posted here." from hereJust curious what percentage of folks actually like reverse clickies. Personally, I don't understand why anyone would prefer a reverse clickie, but please do NOT let my opinion influence your vote! :devil:
2 now! But seriously, there are reasons why reverse clickies might be preferred, in terms of reliability and accidental activation.Ok, fess up - who is the ONE vote for a reverse clicky??? GET HIM!!!!!!!!!!!!!!!!!
Generally I prefer forward (if the mode changes are not done by the clicky). Hate to use the momentary if it starts in lo, and changes modes on me every time i momentary.
So if it change modes via the clicky, i prefer reverse.
I prefer forward-clickies as well and have blinded myself on more than one occasion when using a forward-clickie to switch modes on a multimode light. Also, any sort of signallng is now useless with multimode / forward-clickie. Luckily, there are some lights (Sunwayman, JetBeam) that use a secondary ring to change output which helps.Exactly. For a single-mode light, forward clicky is nice because it gives you momentary. For multi-mode, if you only have one button, reverse clicky is a better UI because it doesn't force you through a stroboscopic full-on/full-off for every mode change.
But.
Conflating mode with on/off in single button is a bug. There is no good way to do it. It's like having your car's steering wheel also control the stereo volume, depending on how tightly you grip the wheel as you're turning it. It is guaranteed to lead to operator error.
