brandocommando
Here are my (first) 2 recent Maglight projects. They are both powered with 8000mAh Tenergy Centura LSD NiMh D cells.
The first one is a brand new 3 D, I went out and bought just for modding. It has:
H22A heatsink
U2 (1C) XM-L on a 20mm star
DX glass lens
2.8A SB driver modded with 4 additional AMC 7135 chips
Stock reflector (modded)
Stock switch (modded)
This total set-up cost around $50! It is set up for L/M/H operation, and it works fantastic. It has momentary activation, and I can change modes with a simple soft press. It is very bright, and has a really nice beam. I used Arctic Alumina Thermal Adhesive to mount the LED and the driver, and some Arctic Silver 5 thermal paste around the heatsink. I was hoping for around 4A on this one, but with only 3 D batteries I am getting only around 3.3A. I tested it with 4 cells and it went up to 3.9A. Should have gone with a 4 D I guess, but I can live with it. I like the smaller size of the 3 D, and 3.3A is still pretty good! This Maglight still surprised me when I took it outside for the first time, it has GREAT throw! I went the cheap route on this one and am just using the stock reflector. It was easy to cut, and was all I could figure out for use with that big 20mm star. I got lucky, this combo actually works great when properly focused, which is easy, because the cut out in the reflector fits around the outside of star allowing full travel.
The second one is a VERY old 4 D Maglight I have had since I was a kid. After being bit by the flashlight bug, it was killing me having this useless old light collecting dust. I had to do something to save it from the trash heap! I bought a bunch of parts from another CPF member and put this together. I couldn't decide on a driver to use for the SST-90 at first. I knew I wanted multiple modes, so I eventually decided to just use another 2.8A SB driver... I have been pretty successful modding them in the past, as I have built several 4.2A p60 modules. I decided I was going to really go for it with this one... It has:
BrightLumens SST-90 heatsink
De-domed SST-90 (unknown bin)
DX glass lens
2.8A SB driver modded with 16 additional AMC 7135 chips!
BrightLumens 17mm aluminum OP reflector
I am not sure, but I would say that this one cost less then $100. I got the SST-90, the reflector, and the heatsink for around $50, on CPFMP.
It wasn't easy modding the driver, but it fired right up the first time! It is also set up for L/M/H operation. I guess I have gotten pretty good at soldering those chips! There are 3 chips stacked all around on one side, and 3 chips stacked all around on the other side. A total of 24 chips! It also has momentary activation, and I can change modes with a simple soft press. It is very, very bright, and has a really nice beam. I used Arctic Alumina Thermal Adhesive to mount the LED and the driver, and some Arctic Silver 5 thermal paste around the heatsink. I was hoping for around 8A on this one, and with the 4 D cells I came pretty close! It does not throw quite as well as the 3 D XM-L, but it's not too bad either! This one is also focus-able (obviously.)
I will be building an aspheric Maglight next, just waiting on some parts to arrive... Stay tuned!
H22A heatsink
DX glass lens
DX glass lens
