deckofficer
These are new to me, I know they have been around for awhile, but just bought it last week and received it today. The battery for it, ordered from a battery vendor, came in last week. The LED flashlight is custom built by Wayne in Oregon. Uses Three Cree XM-L LEDs, 1000 lumens each, a total of 3000 lumens, and it is bright. Uses one 26650 or 26700A LIMN battery rated at 3600 mA/hr 3.7 volts and the light pulls 12 amps, so run time is around 22 minutes. But here is the math 3.7 X 12 [FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]= 44.4 watts. Now I know your thinking a 60 watt incandescent isn't so bright for a household bulb, but your forgetting lumen output for LEDs are 10 times that of incandescent, so now those 3000 lumens is around what a 444 watt (500 watt if you will) shop light puts out. And it is directed light instead 360*.
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif][/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]Notice the heat fins on this Big Bruiser? That is its name. Milled from a solid chunk of [/FONT]aluminum.
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]This is home lightning by some globed CFs.[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]This is with the older power light, the good old 6 volt lantern with a 20 watt quartz bulb.[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif]And the LED Big Bruiser.[/FONT]
[FONT=Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif] [/FONT]
Just porch lights
The 6 volt lantern style beam light.
The Big Bruiser LED
[/FONT]
Just porch lights
The Big Bruiser LED
[/FONT]
