mobile1
hi I am trying to do a 3x5w mod (similar to Flash's), and I need some help with the electrical part (as I don't know anything about it). So some help would be greatly appreciated.
Here is what I want to do:
Leds: 3 x 5w
Regulation: Badboy(s) 700
Battery Voltage: between 15V and 24V (10'000 to 15'000mAh)
My questions are:
1) How many badboy sandwiches will I need - 3-or can I do it with less?
2) What is the maximum battery voltage that I can use (the badboy specification say to not use more then the output V, which in my case would be 3 x 6.2V=18.6 - is this correct?
3) Why is the badboy output 6.2V when the typical Vf according to Luxeons 5w Spec-sheet says 6.8Vf?
4) Why is the bb700 output voltage a range between 4.0 and 6.2V - what determines the real voltage? the Led? If so, isn't the voltage supposed to be the same all the time?
5) Why does the BB700 specification say Maximum Input Voltage 9V when the input voltage must not exceed the output voltage - which is with a 5w max 6.2V?
6) How do I need to assemble everything (wiring)? Are the 3 x bb700 (I assume here that I need 3) to be mounted parallel (each one followed by the led) on to the battery, or is there a way to do it all in series?
7) Is there anything else I need to do my mod (other then a massive heat sink?)
Thanks for helping
Leds: 3 x 5w
My questions are:
Thanks for helping
