Re: JetBeam PA20 or Klarus XT2A or Eagletac P20A2 MKIi S2
I am lost, looking for any insight on this. I think the XT2A may throw the furthest but I had a JetBeam PA40 and that was one tough light.
The P20A2 so far is catching my eye as it seems it may acutally be the brightest with the best throw.
Any input would be great. I plan on using if for the usual. Bunker exploration, hiking, urban exploring, etc. Thanks for any helps guys.
I have both the JetBeam PA20 and the Klarus XT2A and they are both great lights. As for brightness, they seem to be more or less the same. For the throw instead, the PA20 seems to have a slight edge.
I'll try them side by side tonight and let you know what I think. I might do a couple of beamshots against the wall if you think it would help. If you have any preference on the distance or camera settings let me know though: I'm hopeless at taking pictures! :naughty:
Other notable differences between the 2 flashlights:
PA20:
XP-G R5 with SMO reflector
Opeartion: forward clicky with momentary and twist-head with 1 turbo on tightened bezel + 3 output levels + 2 non-hidden flashing modes with memory on loosened bezel
Pocket clip
No diffusers available - the Fenix camping lampshade is the only one I found that fits
Can tail-stand on a flat and even surface
XT2A
XP-G R5 with OP reflector
Opeartion: double tail-switch with momentary on for easy 1-hand operation with 3 output levels with no memory (high always comes on first) + hidden strobe
PWM - not visible but on mine a hissing sound can be heard if the flashlight is placed close to the ear
No pocket clip - I find this to be less of an issue with the XT2A than with the XT1A though
Pouch is useless as the flap is too short and the velcro won't close without activating momentary on
Klarus white and red diffusers available
Cannot tail-stand
If you have any questions feel free to ask and I'll try to answer them - assuming they are not too technical for me! : )
You have probably already seen this
mini-review but in you case you didn't check it out as it has some very useful info on the JetBeam PA/PC Series and the PA20 too.
I have no way to compare the PA20 and the XT2A to the Quark X Tactical or the Eagletac P20A2 though.
Hope it helps,
L
PS: I was undecided between the PA20 and the XT2C and went for the first. Within 2 months I found myself owning both! If you find yourself staring at pictures of both lights for too long, for the sake of your hard-earned savings, I strongly recommend you immediately switch off the PC and turn on all lights in your house to tell yourself you don't need another flashlight! Also, this forum can be dangerous, I really think they should have a health-department warning people on the potential side-effects of membership! :devil:
