I'm trying to upgrade my Fenix E21 to an XPG high CRI, Illumination supply finally got some in on boards, 10mm, not the 20mm I really needed and I thought I could make it work. I can't! The board is thicker and the bezel has to be tight to get both modes to work, no real way to mod it all etc.........
So, I measured and the dies are the same size, and I've read and read on this, but it's still the unkown to me!
So how hard is it really? How much heat? How much heat is too much heat? Meaning I don't want to melt the die's!
My "plan" is to set both of them in a pan, heat them together facing the same way, then remove the one from the original board, immediately take the high CRI die off and set it on the old board and let cool. Good plan or not?
Sorry for the newbie questions, I don't mind having to get another LED, but I don't want to screw up the original board!
Thanks for any and all help/suggestions you can give me on this!
