Bolster
I've been having good luck modifying low-quality narrow-beam headlamps with rattle-can Rust-Oleum Frosted Glass.
Just tonight I modified my daughter's purple/yellow narrow-beam PT Bot, and a vernable old Petzl Tikka. On the PT Bot, the Frosted Glass (sprayed directly onto the LEDs) mixed the purple and the yellow so the result is a much whiter beam, without the artifacts. It also spread the beam.
I photographed the beam of the Tikka before and after, using the manual setting of my camera so you get exactly the same exposure and field of view for before and after the modification. I much prefer the smoother wider beam (and mellowed hotspot) for work. Obviously it diminishes throw, so it's a 'worklight' modification. Not recommended for night-hike lights and the like.
