New Trustfire SST-90 TR-J10 powered by two 26650 batteries
utlgoa
Ohio
So far I've found this light for as little as $134.00 including the charger/batteries, and free shipping. It has an 80 minute runtime on "High" thanks to the two 26650 batteries.
Specifications
1. with the United States LIMINUS SST-90 Led, brightness 2250LM, life 100,000 hours!
2 .intelligent digital circuit control, five mode memory dimming function.Operating voltage: 8.4V, the maximum output current: 5000mA
(1) High : 2250LM
(2) Middle : 1200LM
(3) Low: 225LM
(4) Strobe : 1200LM
(5) SOS: 2250LM
3. Concentrator systems: Vacuum plating mirror reflector, concentrating the perfect, soft spot.
4. Case: aviation aluminum alloy, CNC machining, Army regulations three hard oxidation treatment.
5 with two 25500 or 26650 with the protection of lithium batteries, Hi mode duration 80 minutes.
6. Reprovision extension tube, touch switch, dimmer comfortable, fast.
7. Features: inverted, as the lighting.
8. Dimensions: 217.5mm (length) × 33mm (body D) Extension Tube Size: 44.5mm (length) × 33mm (body D)
I don't think you will find much interest here in TrustFire products. I have the X6 which I have found very reliable and VERY well built - but the consensus here seems to be that all *****Fire are unreliable crap. It probably is true of much *****Fire but not TRUSTFire in my experience although the TrustFire 'Flame' batteries do generally seem to have had a good reception on CPF.
utlgoa
Ohio
This is an SST-90 based flashlight that is regulated and powered by two 26650 batteries......and you can get it for $84.00 without the charger and batteries if you shop around, or you can buy another SST-90 light for almost twice the price.
To bad it's labled Trustfire.
Jay T
Specifications
(1) High : 2250LM
At the listed current the top bin SST-90 puts out 1300 to 1500 lumens. To get to 2250 lumens you need a 9 amp driving current which this flashlight does not do.
