witness
I've read that overdischarging a Lithium Ion battery is a good way to ruin it. In the Zebralight SC600 how does one avoid overdischarging the 18650 battery?
Well more than 2 weeks ago (17 days in fact), in response to your thread on "Why use rebranded batteries for Zebralight H600?" i posted this
"You could if you wish! The H600 has a nice auto cutoff at 2.8V so it is quite safe. However, in lights without that cutoff it would be more advisable to get a protected cell like a Kallie's Kustom, Redilast or AW. They all have a PCB circuit that cut offs when either over discharge, overcharge or over current is detected. All of which WILL cause the cell to vent under different circumstances, hence, the vent hole you see at the tip... And venting in a waterproofed light is a bit like a hand grenade... But most often, people who have ran torture tests just find that the gas escapes through the glass window and destroys the light, instead of exploding, which is a good thing."
And others in that thread have repeated the same proposition that there is a solid cutoff on that Zebralight and therefore a protected cell was not really required per se unless a double failsafe was desired. I'm not trying to be a "smartguy" and in fact there is no tacit implication of that at all in my post. I was simply trying to save some clutter as i believed reasonably that the question had been answered.
Regarding the 3.4V point, going below 3.4V won't hurt most 18650s at all, in fact the NCRs are designed to discharge down to 2.5V so you lose part of its capacity at 3.4V. The 3.4V is true for older Li-on cells but AW didn't update that spec for his newer cells, leading to some confusion.
