Hey guys. I have both blue Preon 1 & Preon 2. Although a few months old, they're still practically new and hardly used.
A few hours ago, I switched on the Preon 2 to check on something and saw that the light was very faint. So I thought, the batts needed to be changed. After putting in fresh batteries, I turned it on but was surprised that it wasn't as bright as it should be. Curiously, I put the old batts in the Preon 1 and it lit up perfectly!
So I compared both lights and saw that the Preon 1 with old batts was a lot brighter than the Preon 2 with fresh batts. I even switched the two heads. When I put the Preon 2's head on the Preon 1, it lit up perfectly again.
So, what could be the problem? Would appreciate your inputs. TIA
Marc
Marc
