Re: Reflector cleaning HELP!
Okay so the reflector in my torch had dust on it out the box. I went on eBay and got an "air duster" to clean it with and its left loads of marks like water marks on it! I know not to touch the reflector but how do i clean of these marks! help!
Air duster cans are prone to spittle and spew it's liquified contents especially if it's new and filled to capacity or shaken when spraying. You can't machine gun your way with it onto a reflector dude. That said your reflector now has residue from the evaporation of spewed *-fluoroethane on its surface.
I'm unsure if a pure alcohol bath would clean it.
For anyone needing to clean dust off the reflector it can be done with this following method I created. Works for lens optics as well:
Using a clean scissor or knife, cut a length of cotton sewing thread and string it through a snipped length of the airduster's original nozzle tube - about 3". You want to seat the nozzle tube back into the head with only about 2mm of thread exposed at the end. There is a reason why you want so little:
The exposed thread will stretch when output pressure is applied. It will extend a few extra millimeters and begin to twirl
making it an ultra gentle agitator to grab dust and blow it away.
You only want to apply minimal pressure and some surgical maneuvering to ensure you don't bump the plastic tube on the
reflector surface. Minimal pressure also helps ensure the liquid contents from sputtering out.
Hope this helps.
