BirdofPrey
- Joined
- Jan 12, 2007
- Messages
- 449
For the past 9 years I've been working primarily indoors at my job. I mainly used my light to get the attention of "residents" that may be in the process of doing something that my job dictates I need to stop.
Starting this coming Sunday, I start a new job (FINALLY) that will place me outside of these dorms and have me during security sweeps. Part of this job will require me to check for contraband that may have been thrown over a fence or placed by work crews.
In particular, I have an area the size of a full size running track that I have to inspect very well and it is littered with scrap wood and saw mill equipment. My current light is a 4Sevens Maelstrom G5. It does the job but I'd like something brighter that puts out a larger "wall" of light. I still want throw, I just need a bigger area of light. My biggest problem is that I have a relatively small window of time to do this sweep as its in an area that removes me from being able to respond quickly to emergencies. This is the reason I'd like to have a brighter light that also lights up a larger area so I'm able to scan more area in less time.
The reason for the "real world" in the title is because I don't want to buy anything special to do this. I already have 18650s ranging from old beater Tenergy cells to the new 3100 Eagletacs. I'd like something that will run well with the Eagletacs.
I've got brighter lights but they are too large to bring inside the fence or to haul around for my regular 12 hour shift as I need something that will go on my duty belt. I looked into a light (can't remember the name at moment) that was stated as putting out 700 lumens while being the same size as my Maelstrom. Problem was, as I researched it, I found it required an extension tube and a second 18650 to get that.
Heat shouldn't be a problem. The longest the light will run at one time will be 10 minutes MAX. More realistically it will be run for 20 to 30 seconds at a time with about the same amount of time in between as I walk in and out of the areas I need to be scanning.
So, help me out. Am I already equipped with the best I can wrangle up or is there something better?
