ericjohn
I don't know what in the hell is going on. I have a Fulton MX-991/U. It has worked okay up until this point. It doesn't come on. I loaded with with 2 slightly used Carbon-Zinc D batteries. I took the "head" assembly off with the batteries still in there. I turned the switch to the on position, then pulled out the electrical multi meter. Hooked both of the test probes to each of the contacts, and got a reading of ~2.6 V. I have tried different (new) bulbs. I have tried taking off the head ring and pushing the reflector with bulb to the back as if it would be in the head ring, with the switch on. All was done in vain. What is wrong all I could think is that it's either demon possessed or haunted.
