Bigpal
- Joined
- Jun 8, 2010
- Messages
- 234
Hello everybody,
I am eager to build my first torch from the ground up, but I am learning the electronics and components functions first and also waiting on parts. So, for practice, I decided to completely disassemble a torch I have and reassemble it.
I desoldered all wires, removed the star from where it was mounted, removed and desoldered the driver, and cleaned off all the solder with a desoldering bulb. I wanted soldering practice and the feel of actually building a light so I reassembled everything as it was.
The problem is it gets WAY hotter than before. Actually too hot to hold and I know something's not right because it actually melted a plastic piece that sat over the star. The battery was too hot to hold also and this is what worries me most; I don't want to blow up.
What could be causing this? Is it possible I used higher resistance wire? It looked the same gauge to me but I don't know for sure. I checked the following before I posted:
-made sure the driver and LED were connected correctly and there are no shorts
-made sure that everything was making contact as before so the heat dissipates through the head
-made sure I didn't use too much solder that would cause more resistance
Thanks a lot for any help.
