not quite sure I understand what you're asking... the wavelength of those LEDs is determined by the die. If you change the current, you will change the brightness, but I believe that you are only going to change the overall magnitude, not the wavelength. If you need (want) shorter wavelength, you'll have to get shorter wavelength devices. If you want shorter wavelength devices (375nm, 365nm) PM me.
Paul
