Incendio V3U XM-L Battery Problem?
coltchris
NW Michigan
Purchased subject EDC light about three months ago & really like it. However, I now can't get it to work on RCR123's; works fine on primary SF 123A's! I have (2) AW RCR123's & (2) EagleTac 16340's, all 750 mAh. The AW's read 4.12v & the EagleTac's read 4.08v after charging about a month ago on my Pila charger. I've tried everything I know (not much!) and cannot get the re-chargeables to work. Any ideas for an old newbie? Worked fine on the re-chargeables in the past.
coltchris
NW Michigan
Contacted Tod at Illumination Gear; problem solved! No problem with flashlight and batteries good EXCEPT + contact didn't protrude high enough above battery casing. Gently pushed casing down to avoid interference and the AW's now work fine. However, the EagleTac's still do not work; couldn't push casing down enough.
