The_Driver
I just did some ceiling bounce measurements with my DX lux meter. My ceiling is white and has a rough texture to it. The lights all stood in the same pace on the floor and the lux meter's sensor was about 1 foot away from the lights. The lights were either tail standing or pressed onto the ground if tailstanding was impossible. All lights were in their brightest mode (unless noted otherwise) and were measured 1-2s after turn on. Except fo the VPT the measured values didn't change too much during the first minute. I thin the readings for the throwier lights are a little bit too high, but I can't check this accurately. Also note that my VPT V2 is the 4000K de-domed version and it has an aftermarket UCLp lens with 97% transmittance which is probably 5-10% better than the stock mineral glass lens.
Here are my readings:
The calculated lumens were based on the HDS edc burst mode measurement since this does exactly 100 otf lumens. After 4 minutes the VPT was too hot to hold :laughing:. If you have any suggestions or questions just say so .
