HI have a quark AA regular UI running on a AW 14500. When I turn the light off it takes almost 30 seconds for the light to reset to moonlight. Is this normal because of the extra voltage? When I run a AA Eneloop it resets in about 10 seconds.
Mine does not do that. It resets in about 5 seconds or less. In a recent thread, I suggested to someone to clean threads and make sure he is loosening the head enough because weird things happen when the head is on the fringe of tight/loose. He wrote back that loosening the head more did help him out with this problem.
But there is another recent thread in the CPF Marketplace where others are complaining about this same issue. My quark is one of the very first ones, so maybe newer ones might have a problem. I don't have the link handy and I'm running out the door. It's in the 4sevens section of the cpf marketplace and was around early May, so it should be easy to find.
If making sure the head is loose enough does not help, I would contact 4Sevens for warranty service.
I used it without any problems as a 1AA eneloop, a 14500, and with a primary 123 and a 16340. All reset in under 5 seconds. This is a very early model, maybe things have changed.Do you run yours on li-ion, or primary/NiMH? I recall that this happens with the regular interface/UI and while on a li-ion.
I cleaned the threads when I got home from work tonight and it helped some. Now with a single Eneloop it resets in 3 to 5 seconds, but with the lithium ion it still take over 20 seconds.
If it does not bother you, just enjoy it. But if it does bug you, then I would press them on the issue to replace it.I called Foursevens today and they said the 3 seconds reset time was with alkaline batteries. With lithium ions it would be longer.
Interesting find. I've just checked my sample(less than one year old) and it takes 15 seconds to get back to moonlight on an AW 14500, 3 to 5 sec. on eneloop! Hmmm....HI have a quark AA regular UI running on a AW 14500. When I turn the light off it takes almost 30 seconds for the light to reset to moonlight. Is this normal because of the extra voltage? When I run a AA Eneloop it resets in about 10 seconds.
Mine has the pre-flash issue.I'm wondering if these lights with a long reset time still have the pre-flash problem? If you are not familiar, many quarks give a brief bright flash when first turned on. Mine is a very early model. It does have a preflash, but always resets in under 5 seconds. Just wondering if the long reset might be related to fixing the preflash.
I just swapped the head with my AA2 X and now the light resets in 5 seconds like it should. Man that X head on a 14500 is a real pocket rocket. I think I just found my new EDC light.
