skeeterbait
- Joined
- Oct 26, 2003
- Messages
- 163
OK, I purchased an Everled pr-flange bulb. The intended host is a Sears Craftsman rechargable lantern. The lantern has a six volt sealed battery. I read on an old post where the Everled can be ruined by reverse polarity. So before installing it I checked. Sure enough, the negative post on the battery leads to the tail of the bulb. To correct this, I simply reveresed the wires on the battery terminals. So now the question. Since reversing the wires on the battery terminals, shouldn't I reverse the wires on the recharger plug also? I can do this simply by cutting the wires at the plug where it plugs into the light and rewiring them backwards. It seems logical that this would need to be done. Thanks for your help.
