My Fenix PD30 started to burn, and caused extensive smoke damage to our home!
Here is the story, We often use our LEDs with very low light capacity to provide area or bathroom lighting at night, esp when we have guests. Last week, I turned on my Fenix PD30 on the low setting and left it for several hours. It was using Tenergy RCR123a 3.0v batteries which had about five previous charges on them. The batteries were not freshly charged, having been used four or five times after being charges for five or so minutes each time. I turned on the PD30, and several hours later the whole house was filled with extremely pugnent smoke. We ran around to find the source. The light did not appear damaged, unfortunately, I made the huge mistake of picking up the light to inspect it, and my hand was seriously burned.:fail:
I was in contact with 4 Sevens where I bought the light. Today their customer service responded by e-mail. Part of their note says:
"Also, I wanted to let you know the problem youare having is more than likely a direct result from your batteries. RCR123'sare not compatible with the PD30, it is too much voltage. On the productlisting it states it is compatible with 3 volt lithium batteries only. What youhave been using is 3.7 lithium ion batteries which will not only cause yourlight to not work properly but it can also cause it to heat up too much."
I did not tell them that I was using 3.7v RCRs, only that I was using RCRs. I re-read the literature supplied with the light, and it does mention RCRs at all.
So, bottom line: Beware, and do not use any RCR123s in the PD30 (or any other light for that matter that does nto specifically recommend their use.)
(((As a side note. This is the third Chinese made light I have problems with in the past year. (Quark AA, PD30 R4 and PD 30 Q5.). After several months and many e-mails, the other two were repaired or replaced. I am not going to try on this one since it was apparently my mistake for using the wrong batteries. I have never had a problem with any of my Surefires or Malkof dropins using the same batteries (other than a couple begginer mistakes years ago: namely instantly blowing some bulbs when inadvertantly installing the wrong battery, such as RCRs with a incan lamp).)))
