I just got one that I keep wanting to blurt out while reading numerous threads.
When evaluating a light multiply lumens by runtime to get "lumen X hours", this will let you see the overall efficiency of the light and which levels that the light produces are it's sweet spots.
Also, you could take the same lumen/hours number and divide it by the (voltage X miliAmp hour rating) of the battery chemistry of the light in question to get an overall equivalency between lights.
For example, Zebralight makes the H51Fc which has a sweet spot of lumens/hours at 345LumenXHours at M2 (15 lumens for 23 hours)... Incidently, M1 and L2, the settings above and below M2 are both nearly as efficient at around 336 LumenXHours.
Anyways, take that 345 lumen X hours and divide it by the Watt hours of the cell chemistry to see the overall efficiency of the light... in this case an AA 2000mAh Eneloop with estimated 2.4 Wh gives an overall Lumen X hours / Watt hours score of 143.75
Then the backpackers can divide that number by the weight of the light and battery to get their overall useful light per gram.
That's all I got for now, -other than that if you ever find yourself in need of a very small quantity of high quality machine oil, just rub the part along the side of your nose, just as good as whale oil without the ethical dilemmas.
