This is for any g25c2 owner out there. Whenever I twist the head to change mode, my g25c2 makes some clicking sounds, the sounds that a spring makes when you twist it. This only happens when I use eagletac 18650s. It doesn't happen with cr123s. The sounds come from the tail switch, specifically from the 4 small springs inside the tail switch. I think when I twist the head, it in turn twists the battery and the battery in turn twists the springs making the clicking sounds. I think because 2 cr123s are smaller and shorter than a 18650, they don't have this effect. Does this happen to your g25c2? Any idea how to fix it?
